Go to primary content
Oracle® Retail Functional Artifact Generator Guide
Release 16.0
E80316-01
Next
Contents
Title and Copyright Information
Send Us Your Comments
Preface
Audience
Documentation Accessibility
Related Documents
Customer Support
Review Patch Documentation
Improved Process for Oracle Retail Documentation Corrections
Oracle Retail Documentation on the Oracle Technology Network
Conventions
1
Introduction
Concepts
Functional Artifact Types
RTG XML Schemas (XSD)
RTG JAXB Java Beans
RTG Objects (Oracle Objects)
Sample XML File
Technical Specifications
Supported Operating Systems
Command Line
Graphical User Interface (GUI)
2
Installation and Basic Setup
Determining the Type of Installation
Installing As a Standalone Application
Installing As an Application Inside rib-home
Installing As a Web Application in Oracle WebLogic
Prerequisites
Deploying the Artifact Generator Application
Creating the agAdminGroup
Verifying the Artifact Generator Web Application
Redeploying the Application
3
General Usage
Customizing Payloads - Prerequisites
Rules for Customization/Extension
Directory Structure
Customization
Localization
Customizing and Localizing the Template Creator
Template Creator Overview
Arguments
Commands
Template Creator - Command Line Interface
Using the Command Line Interface
Customizing Or Localizing the Elements
Adding Customized Optional Elements
Adding Localized Optional Elements
Adding Elements To A New ExtOfxxx.xsd
Creating a Work Area - Graphical User Interface
Template Creator - Graphical User Interface
Using the Graphical User Interface
Graphical User Interface - Examples
Adding Optional Elements
A
Appendix: Install the Artifact Generator
Creating the Role/User in the Artifact Generator
Installing as a Web Application in Oracle WebLogic
B
Appendix: Example of Customization and Localization for ASNInDesc
C
Appendix: References
